Map sensor
The rear bung is for manifold pressure/vac, just need an adapter fitting from home depot.
For MAP I used a port on my throttle body because its easy. If you wanted to get fancy you could run a splitter from the rear bung. So run a y-piece directly into the rear bung, feed one line to the MAP sensor and the other to your brake booster line.
