Truck intake guys, how are you plugging evap purge solenoid hole?
Old 03-21-2013, 10:32 AM
Bowtie316's Avatar
Default Truck intake guys, how are you plugging evap purge solenoid hole?
I have searched and searched, found several threads with no answers and a couple other threads where someone milled their own billet aluminum piece to plug the hole. I don't have a mill so that is out of the question. Has anyone tapped and plugged it with a pipe plug of some sort? Is there a better way? I'm not finding any parts available for this.
This is what Frojoe did. https://ls1tech.com/forums/14940065-post470.html
Thanks for any help.
Old 03-22-2013, 07:50 AM
gagliano7's Avatar
I tapped and used a plug worked perfect.I put some rtv on the threads.
Old 03-22-2013, 07:53 AM
Bowtie316's Avatar
Do you remember the tap/plug size?
I'll probably just dive in and figure it out, was just trying to be lazy. I will post back with what I came up with, but it won't be fancy lol.
Old 04-01-2013, 08:02 AM
Bowtie316's Avatar
This is what I ended up doing. Cut the evap solenoid off right above the hold down flange. Tap the hole to 10-32. Put lock-tite on a 10-32 screw and screwed it in.
Old 03-14-2014, 09:01 AM
ryanleiker's Avatar
Any follow-up on tapping this hole for pipe threads and putting a pipe fitting in it?
I'm looking to put a vacuum tee in it for my wastegate/BOV.
Old 03-17-2014, 12:13 PM
gagliano7's Avatar
I tapped mine and used a plug. I can't remember the size.
Old 03-17-2014, 07:53 PM
ryanleiker's Avatar
Follow up: I went ahead and risked it and tapped mine with a 1/4" NPT pipe thread. I put a bushing/adapter in so I have an 1/8" npt hole to fill with a push-lock fitting for my blowoff valve and/or wastgate.
Note: be careful how deep you tap it because of the taper. There isn't a lot of material to thread so I would tap it in stages until you get the fit you like for the fitting you're using, since its only plastic.
I tapped and put an adapter because 1/8" is more common and I won't have to take the fitting in and out ever again.
Also, remember the thread sealant/Teflon tape.
Quick Reply: Truck intake guys, how are you plugging evap purge solenoid hole?
