ASP pulley?
I just got the crank pulley and no problems with charging. Keep in mind there are two alt pulleys you can get: underdrive and overdrive. Can't remember which belt, but the places that sell the pulleys usually set you up with the correct belt as well. If you have a faster than stock idle speed, I would consider an underdrive pulley for the alt also. Otherwise best to stay stock on alt especially with an A4.
