Tap oil oan
Old 11-24-2013, 06:52 PM
Transam408's Avatar
Default Tap oil oan
Can I use earls bulkhead fittings to tap either the oil pan or the timing cover.
Old 11-25-2013, 12:57 PM
usdmholden's Avatar
If you mean to drill a hole in the oil pan and timing cover and tap them, I think the walls will be too thin.
My oil pan walls are just over .100" thick and I doubt the timing cover is any thicker.
Old 11-25-2013, 02:01 PM
Burken01's Avatar
Buy a welded bung in the size you need and find a local welder in the yellow pages..
Guy charged me $60 to weld 3 bungs into my radiator and trans pan..
Quick Reply: Tap oil oan
