Stock headers or shorty???
I have an L33 5.3 with an LS6 intake, ported TB and the heads have had multi-angle valves/seats cut and Pac 1211x springs.
The rest of the engine is stock but I plan a cam change in the not too distant future to something in the region of 220 to 228.
The engine does not currently have any headers so I am starting from scratch however the space around the engine is very limited.
As such I can only fit shorty style headers or stock headers.
Can anybody give an expert opinion as to what would be the better choice of the two?
Thanks in advance for any replies.
Shorties tend take on the same install height as long tubes..only thing being different is shorties do not go all the way down to a collector. If space is an issue then I would say stick to manifolds.
If you want a better stock exhaust manifold go with a set off of an 00-02 Camaro/Firebird LS1...those are supposed to be better designed for flow compared to earlier versions.
You could also try fabricating your own set of headers...or have any reputable exhaust shop fab some up.
Thanks all for the replies.
So you can get an idea of the problem I face I am building a Caterham 7 style kit car using this engine.
As such space is extremely limited around the engine bay and the usual method for the manifolds is to exit straight through the side panel.
The simplest way is to use a manifold/header which has a single pipe connection still within the engine bay and then pass that single pipe out through the side panel.
There probably just isn't the room for all 4 tubes to be within the engine bay hence why shortys or stock headers will make the install a lot easier.
I'm not in a position to need more power/torque than the cam change I propose since the car will only weigh about 1600 pounds with me on board and a full tank of fuel.
Any idea what the weight differences are between stock cast and a set of Stainless shorty headers?
As far as I can tell, buying a set of Shortys wont cost a lot different to a pair of Stock headers.
I definitely think Shorty headers are the best option.
Thanks again to all.
