Coil wire or coil issue?
Old 03-06-2014, 08:59 PM
joshua022's Avatar
Default Coil wire or coil issue?
I have msd wires and stock truck coils and one of my plugs refuses to snap into the coil and is causing a miss.
Any ideas if it's the brand new wires with less than 300 miles or the coil in some way?
Thanks
Old 03-07-2014, 12:19 AM
Mike_hawk's Avatar
You should swap the wire to another coil, and put dilithium grease on the coil. To see if it's coil or wire. If it's the wire the part that snaps on the coil is either too large or too small, you can squeeze it a little or expand it with some needle nose pliers.
Old 03-07-2014, 10:40 AM
Gray86hatch's Avatar
The joy of imported MSD junk.
FFirecore50 best wires I have ever had.
Tim
Old 03-07-2014, 10:50 AM
Orange Juice's Avatar
try one of your stock wires in the coil.
Old 03-07-2014, 06:24 PM
joshua022's Avatar
I got it, the connector on the wire wasnt real tight
Quick Reply: Coil wire or coil issue?
