close up pic of 4150 throttle body with cable???
ok i know ive searched and i know i can use a lokar cable and many brackets, but im looking at all the pics, and i dont want to buy the wrong thing.
i have no idea how to mount a throttle cable to my 4150 tb and edelbrock victor
close up pic please?????
You will want to put about a 1" spacer between the throttle body linkage and the ball on the throttle cable. I have a 3/4" spacer I'm going to add another 1/4"-1/2" to get everything to line up a little straighter.
That's what I thought but had to ask. Thanks for the info. I just bought my super victor today so I'll be using your setup as reference. You running a extended Sunoco hood as well?
Hey OP, I will sell you my throttle cable and some ARP carb studs. PM me if your interested.
I bought it from a local hardware store.
The bracket is from Summit part # SUM-210240BLK. Yes the springs come with it.
For a 441ci motor that should spin to 8-8500rpm and make 650-700rwhp....what size TB should I run?
What manufacturers make them?
Approx cost?
Also what air filter options that are more low profile if possible.
It has AllPro LS7 heads and AllPro single plane intake CNC matched.
I'm just starting to research TB info for this.
Approx cost?
as far as a throttle cable....
you can buy the Lokar piece for the throttle cable bracket separately and then go to the dealership and buy a 99 Fbody Cable for a Non ABS Non Cruise control car....if you need a 4150 style carb end, then you can just go to orileys and but the carb end for about $5
cut the throttle cable off to the length you need it to be and put the carb end on it
otherwise, you just buy the Universal Cut to fit cable from Lokar with the end you need for the pedal side of it.
I had the CSR bracket....but its made for a Carb, not an EFI 4150
and it lines up like ****....
so I made my own bracket that lines it up correctly
This picture was from when my Motor was running with a 350 shot of nitrous.
