Ls1 injector ohm readings
Old 09-17-2014, 07:20 PM
92rspowerdbyvortec's Avatar
Default Ls1 injector ohm readings
I bought a used set of stock Ls1 injectors and they ohm from 12.7-13.3 what should they ohm at?
Old 09-18-2014, 09:22 PM
soundengineer's Avatar
that sounds about right...
usually injectors are anywhere from 10-16 if they are High impedance
also, an ohm test is inconclusive unless one of them is WAY out of range of the others
only way to know if they are good or not is to have them flowed and tested
Old 09-19-2014, 12:47 AM
Thanks
Quick Reply: Ls1 injector ohm readings
