untuned crazy
untuned crazy
I got motor all runnin ms3 cam ls1 little bump in compression 243 heads ls6 intake wilson 94mm throttle body bigger injectors there the svo red ones headers so it fires up runs but it is super slugish free reving its really rich at idle shakes fairly decent at idle idles around 1000 rpm should all those mods make it run like that i know i need a tune i just dont wanna get on dyno and have probs ecm was tuned for smaller cam prevouisly or do u think i have something wrong
First of all wtf did I just attempt to read? If you want help you need to post up in an educated and somewhat coherent fashion.
And no it sounds like you just need a tune bad. Big injectors will make the car run really rich, and if not tuned properly can ruin the piston rings by washing them with fuel. A litle cam tune wont do crap on an ms3 seeing as its a huge cam. And there's no way you fit a 94mm tb on an ls6 intake without a huge adapter. In which case do yourself and the tuner a favor and put a stock ported one on.
Yes im gonna get a scan tool from autozone lockdown99ss and see if there are any codes it just revs super slow and dont want to be on the dyno trying to trouble shoot stuff the check engine light is off
Sounds good keep us posted hopefully that solves problem like suggested getting car tuned is good idea that will expose issues and make car run better as well good to invest now with mods cause it be safer and run better as well
You shouldn't even be letting it idle with a bigger cam, injectors, and no tune. Even if it was tuned for a smaller cam. The bigger cam will make it run richer at idle and the bigger injectors will amplify that. You're going to screw things up in a hurry if you don't get it tuned.
I got motor all runnin ms3 cam ls1 little bump in compression 243 heads ls6 intake wilson 94mm throttle body bigger injectors there the svo red ones headers so it fires up runs but it is super slugish free reving its really rich at idle shakes fairly decent at idle idles around 1000 rpm should all those mods make it run like that i know i need a tune i just dont wanna get on dyno and have probs ecm was tuned for smaller cam prevouisly 'or do u think i have something wrong'
