coolant leak need help please !!!
hey guys I have a 01 ss and it has 85k on it. It has a coolant leak and from what I saw im thinking its the water pump. I can see fresh green coolant that has dripped/pooled up all over the front sway bar, the back of the crank pulley also on the other pulleys, and leaking off the oil pan..ALTHOUGH I cannot see an actual drip (possibly the weep hole that cant be seen?. Because my driveway is on a hill, it made it seem like the coolant was leaking from the back of the motor by the back of the oil pan leading me to think a head gasket but its leaking all the way down due to it being on the hill.
Important:
NO WHITE SMOKE OUT OF THE EXHAUST
Oil is Perfect
car has only overheated once due to a low coolant level
before I bought it it had Dexcool in it and I flushed and switched to green
tstat was changed
Belt also Squeaks on cold start
I would appreciate it if I can get some good feedback/conformation that it is not a head gasket or if it is the water pump or something else
thank you
Important:
Oil is Perfect
tstat was changed
thank you
If you haven't already done so, pull the front up onto some ramps or up jack stands. Then with a bright drop light of flash light start the car up and let it get up to full operating temperature while you're under the front looking(with safety glasses on)for the leak source. Then start from the top and work your way down. Start with look around the steam vent tubes where it mounts to the heads up front, or along it's return route to the filler neck on the radiator. I'd also check the rear steam port caps on the back at the rear of the heads. If you found no leaks from the steam vent locations up top then when you remove the water pump carefully look at the wp gaskets since it's common for the factory wp gaskets to leak after a lot of miles. If you find no possible signs the wp gaskets are bad and causing the leak then, I would say you probably then need a new water pump.
I doubt it's a head gaskets, but if all else fails to stop the coolant leak it's always a possibility.
Since it's right there you might want to check the coolant to/from the throttle body and even if it's been bypassed, it could still be leaking.
I would imagine there's a weep hole on the water pumps. Try running your hand on the bottom of the pump for coolant b4 an engine start. If all else fails, you could add dye and check with uv glasses.
Good luck.
Good luck.
Good luck.
Good luck.
as already said, id guess weep hole on the pump (needs a pump replacement) or the mating gasket for the pump to the block.
If you cant pin point the leak you COULD just change the gaskets they are cheap and see if that fixes it or you could go ahead and replace the pump and gaskets which depending on age/miles on pump id change anyway.
If you do do this, make sure you get all of the old gasket off it may require some scraping/picking at but make sure not to damage the mating surface.
