241 head bolt length?
hey guys i got a question. i'm building a 98 ls1 engine and i bought a set of 241 head to put on them from a friend. do the 241's use the equal length head bolts or the different length head bolts and does anyone have the arp part number for the bolts i'd need? thanks in advance
You will need kit 134-3609 from ARP. Two of the 15mm bolts which are 9 and 10 in torque sequence are a little shorter than the other 15mm. This is the Pre 2004 kit I believe. I used this same kit on my head install and I have 2001.
Yep. In the early gen blocks the Med. bolts don't even reach the threads. If you had the long bolts in a late gen block, they'd bottom out about 5" above the head. I have 2 6.0 blocks on stands, one early, one late. I keep an old long bolt handy so I know which is which.
I guess I need to tag them to make it easier
