Need wiring harness help
So I'm finally getting a chance to mess with this 99-00 LM7 I picked up awhile back but the idiots that pulled it from the donor vehicle hacked the ***** out of the harness. I have most of everything on the way to being sorted out but still need to figure out what these two main sub-harnesses coming off the main harness at rear of the intake are. It's the two marked with red tape. Obviously some of the one harness contains the trans wiring, but I'm lost beyond that. Anyone?
If memory serves, the bundle in the first pic (LH side of motor) has the trans and LH front O2 sensor wires. The bundle on the right has both RH O2 sensors.
Best way to tell is ohm each bare wire out to the PCM plugs. Pinouts for the various year PCMs are easy to find online. This won't ID the power and ground wires, but those aren't too hard to figure out.
ok yeah pretty much what I figured as far as those go but there seems to be more wires than just that stuff even if the o2 sensors are 4/5 wire and figuring around 6 to the trans...
