Swivel Thermostat housing.
Do any of you guys use a Swivel Thermostat housing on your Water pumps?
I am using the C6 Ls3 pump and I don't know if the LS1 thermo housing is the same?
The problem is that the LS3 Thermo housing is facing right into the frame rail in my regal. If I have to make it work, I will make a custom aluminum connection. If I could get a Swivel housing that works on the LS3 water pump to redirect it down and away from the frame and out of the way of the turbo Inlet It would be a great day.
