"better" crank pulley bolt ...
What exactly is wrong with a stock bolt you think it needs upgraded? The only negative is that it's torque to yield and needs replaced each time but for the price of the ARP you can buy a **** ton of GM bolts.
The crank in my car had an overdrive blower pulley spin on it so that the crank pulley easily slides on and off with no tools but 2 pins and a stock bolt are holding it on there just fine.
