Help with pcv routing on my 408
So, fiishing up my 408 build and i need some help with the pcv routing. Do i need a catch can? I have the pcv valve in the rear of the drivers valve cover, two emply ports on the passenger valve cover, a port on the intake manifold under the throttle body and no idea what goes where. I bought a filter that has a one way check valve in it that will go on the oil filler. Right now, i have no hoses on any ports. Help.
