Heads & cam for my truck?
OK folks, while I got the Trans Am under control, I'm considering a H&C job on my truck.
2003 Ascender (Envoy) 5.3.
I'm looking for good low end torque but still able to rev high. Will probably go with the TBSS intake manifold.
Moderator
Received 1,852 Likes
What are your goals? At first glance, I'm thinking milled 243's with a tick SNS2. Should have good torque and with the overlap would still rev. The 243 heads will support the airflow
rev how high?
what are you wanting the truck to do? stock converter? I really like my Cam Motion drop in cam. Solid 40rwhp gain over stock but it still has all the same manners as stock even with the factory converter and no headers. It's good for 6,000rpm shift points and I was able to use ls6 springs so it was easy and cheap.
