Poly mounts????
LS1Tech Premium Sponsor
I would definitely recommend going ahead and doing it. It would be the ideal time as everything will be apart giving much easier access to the motor mounts
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Moderator
Received 1,852 Likes
It'll add 5 hours to your header swap or it'll take you 24 hours later to get to them. Plus the added rigidity will help prevent the headers from banging into heat shields, k member, etc
Moderator
Personally, I would say less of a PITA than dropping the oil pan, but more of a PITA than a cam swap.
I don't think doing poly motor mounts with a header install is really a big pain at all. It may add another 2-3 hours to the install time with the headers but you won't ever have a better time to do it. Do it once and just get it done with.
It is way easier doing anything on a lift so that will save you some time and make it easier.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Moderator
Probably. I did it on my garage floor with the car about as high as I could get it.
No, I meant the entire header + polyMM project. Less of a PITA than the oil pan, but worse than a cam swap.
Exactly! If you don't do them and your exhaust starts slapping under your car, it will be a ton more work to do them later.. they are wide open and easy to access with headers off..don't talk yourself out of it or let anyone scare you from doing it.. it's really way easier than most made it out to be
