Slight white smoke on cold starts = bad head gasket?
I posted this in the PCM section but maybe it should be here to get other peoples views too....
https://ls1tech.com/forums/showthrea...475post1443475
White smoke in the exhaust when first starting a cold engine is normal condensation turning into steam. However, it is possible that coolant is getting into the combustion chamber. Your engine’s head gaskets may be failing or you may have a cracked head.
1 Post
Also.. about that plug...
It looks just like mine looked after doing my H/C swap... All it is is carbon fouling. You need to have your tune tweaked and your plugs will be clean as a whistle. Well, at least that solved the problem for me..
How to read a spark plug..
