LT Header Swap, what else should I get done? List inside
I’m going to be doing a header swap and I was wondering if I should go ahead and get some other stuff done while the mechanic is in there.
It’s a 2000 Z28 with around 150,000 miles
Here’s what I have so far:
1) Dynatech Sumermax Long Tube headers & Y pipe
2) Percy’s Header gaskets
3) Stage 8 Locking header bolts
4) MSD 8.5 wires and NGK TR55 plugs
5) While I’m at it, I’m going to be replacing all 4 Oxygen sensors.
Denso 234-4025 - For the front
Denso 234-4617 - For the rear
What else do you guys recommend?
Thanks
Thanks
Prothane motor mounts. You'll need to shave them down a little to fit in the clam shell. I bought a spare set of clam shells and pedestals off eBay beforehand to prep and paint. It was nice not having that added down time in the middle of the project
Thanks
Thanks
2) No need for the fancy MLS Percy gaskets, OEM GM MLS gaskets are good and cheap
5) If you don't plan on running cats skip the rear O2s. If you don't plan on using O2 extensions for the long tubes then you can open up the PCM plug and flip the signal wires in the harness for the front and rear O2 sensors and run them that way.
As stated before Poly motor mounts are a good idea while you're in there.
