No drone muffler suggestions
Old 10-12-2016, 03:43 PM
smitty2919's Avatar
Default No drone muffler suggestions
Planning to build a proper exhaust for my 95 LT1. PS longtubes, catless y pipe single 3" to a ______muffler mounted under the trunk. I'm remaking the merge to flow better and eliminate any rasp.
I'm looking for something fairly tame and no drone as this will be my "winter/windows up exhaust". I will V-Band the exhaust before it goes over the axle so I can make a "summer/fun time" exhaust later on.
A Borla XR-1 seems to be popular for a quality muffler that has a low profile body to tuck up high. Magnaflow would also come to mind, but I have had Magnaflows on a 03 Mach 1 (factory manifolds/catless x pipe)that had a little cabin drone.
I had a Hooker MaxFlow muffler but I don't believe that was stainless, had a slightly tall body profile and was a little heavy.
When I build the "louder" setup I will look into a glasspack style.
Old 10-12-2016, 08:01 PM
gametech's Avatar
In addition to looking at different mufflers, you should look into what a lot of truck guys are doing. With a few calculations that I don't remember off the top of my head, you figure the proper length pipe to weld in perpendicular to your main pipe to reflect and cancel the sound waves at a particular drone frequency. This is typically done for a narrow rpm/load window such as highway cruise speed, or whatever your most annoying nuisance droning condition is.
Old 10-12-2016, 08:09 PM
smitty2919's Avatar
Yes sir. It's a Helmholtz resonator. Installed one on my GTO and currently running one with my Camaro now (glass pack with the resonator tube t'd off running under the trunk).
Not looking to add that though due to space allowed and pipe routing. I can do it with a much smaller glass pack style muffler though.
Old 10-12-2016, 08:16 PM
KissMyWhiteSS's Avatar
I'm in the same boat. The car I just bought has LTs and SLP LM2. I don't mind the rasp, but the drone is brutal.
Old 10-13-2016, 07:23 AM
smitty2919's Avatar
I'm a fan of a smooth note. Ideally i like the LS motor with Corsa exhaust, but a nice Borla/Magnaflow low note is nice too.
A Helmholtz resonator works well. Did wonders for my LT/catless Y and 3" magnapack GTO:
The calculation:
The expanded range to show how the tube length varies depending on RPM. I graphed only the 1/4 wave column I used 29" centerline on the GTO:
Old 10-13-2016, 06:57 PM
gametech's Avatar
Interesting. I wouldn't have even mentioned it if not for the fact that I hardly ever run across one on a car, yet I hear endless whining about drone from car people.
Old 10-14-2016, 11:51 AM
farmington's Avatar
Add cats to your Y pipe.
Old 10-14-2016, 01:11 PM
smitty2919's Avatar
My only issue with that is ground clearance with my Koni/Strano suspension. Adding cats to a 3" y pipe makes almost a 3.5-4" cat body....further reducing ground clearance.
Old 10-25-2016, 02:34 AM
Gooze_1's Avatar
Spintech has no drone on my set up 1 7/8 headers off road y virtually no drops at 70mph
Old 10-31-2016, 08:20 PM
wannafbody's Avatar
Gibson has a burble under 2000 rpm, then it's smooth as butter, maybe a bit too quiet.
Old 11-01-2016, 06:33 PM
01ssreda4's Avatar
Hooker Aerochamber.
Old 11-01-2016, 08:40 PM
Majestic9C1's Avatar
Magnaflow 14419
Old 11-02-2016, 03:50 PM
black sky's Avatar
I would have to say hooker aerochamber as well. Currently using it with ARH headers and catted y. No rasp and Sounds awesome at WOT. One of the best flowing too.
Old 11-02-2016, 08:59 PM
01ssreda4's Avatar
Size:  1.14 MBName:  20160601_201807_zpsmgo6i4eh.jpeg
Quick Reply: No drone muffler suggestions
