Total upgrade cost LSXR102 vs MSD Airforce 102
Moderator
Received 1,852 Likes
I've installed both. Both came with gaskets. Both run the same fuel rail. Both needed oversized injector o rings
And you have no idea who you are dealing with. A little research would answer all your questions, but you chose to ask them here, and when one of the more knowledgeable guys around here gives you a not-totally-comprehensive answer, a smartass remark results. A little respect goes a long way, but maybe I'm just talking to the wall here....
Moderator
Wtf does this even mean? But to confirm his response he's correct, both manifolds come with gaskets and will need ls2/3 fuel rails along with injector adapters and o rings.
If you know what you're doing and can shop around for used parts you can do the swap for under a grand
You should be kind to your neighbors. I believe Darth would have set you one up for $3000 and installed it for free.
Good way to save face, if he can change his antisocial traits, but I wouldn't hold my breath.....
