everyone please tell me how you got your longtube y pipe to not leak
i can hear a slight ticking noise, now either the longtube install made the piston slap louder or the y pipe leaks, its hard to tell. i used band clamps how can i get this to not leak besides weld it
Well you're going to hear some noise because the headers are alot thinner than the stock manifolds. If the connections are downstream from your O2's then you can use RTV to seal the bandclamps. I welded my y to my i though.
Originally Posted by 70T/A400
To perform this properly, the system needs to be taken apart, the joints sanded and then cleaned with brake cleaner. Then apply the RTV sealant and let it cure for 24 hours.
now when i take my band clamps off and put silicone on them and tighten them back down do i have to let it dry for 24 hours or can i just fire it up and go? DAl 1as??
LS1TECH Sponsor
surprised this one hasnt come up yet.
go to the kitchen and get the tin foil fold it wrap aronud the smaller side, install a good clamp, stops 95% of all the leaks ive ever come across, usally bad clamps/bent or dented pipes are the other 5%
