How i ran my catch can
Can some one show me how they have there catch cans hooked up? I mean what do you have going into it and what you have going out. I just have it from the pcv line to the catch can, then the from the can to the pcv valve itself then to the intake. Should i do anything about the lines going to the TB?
Originally Posted by PG45
Does it matter if the Valve comes before or after the can?
PG45, The top hose is connected to the end of the PCV, side hose goes where the PCV hose was.
pdd, Maybe you're getting oil from the valve cover breather hose, try a Metco breather in place of the oil fill cap. They have one that replaces the cap and neck and they have a breather that just replaces the cap, I don't have any part numbers but I think I would just go the Metco breather that replaces the oil fill cap ( much easier install ). JMO
1 Post
Originally Posted by pdd
what,where is the pcv valve? i have my catch can hooked just like dark ages and i still get oil in the intake. do i need something else ???
Originally Posted by Z28Venom
The oil could be coming from your ported heads. Did you use a sealant on the intake rocker bolts? I was having the same problems with my car, and it turned out to be the ported heads..
were do i get on of those? thanks pat
Just checked Fast Toys and it looks like they have it, other sponsors probably have it also.
Originally Posted by DARK AGE 53
Pat, I don't have one but I know someone bought one from a sponsor here, which sponsor I don't remember but I'll see what I can find..you could also start a thread asking where you can get the oil cap only Metco breather.
