people with jet hot headers...
Old 12-11-2004, 04:35 PM
02blackws679ta's Avatar
Default people with jet hot headers...
how do you like them? any complaints? how is the fitment?
just trying to see what the general concensus is on these, i have a chance to pick up a used set with low miles and just seeing if its worth getting them, or holding out even longer for kooks (which ive been wanting forever )
TIA!
Old 12-11-2004, 04:38 PM
TT-TECH Veteran
Inspector12's Avatar
I like my Jet hot's no complaints about the headers I don't like thier Ypipe I prefer the Hooker ORY instead.
Old 12-11-2004, 05:16 PM
do they bang or anything? how is the fitment overall and what not?
Old 12-11-2004, 07:21 PM
TT-TECH Veteran
No fitment issues with the ones I have installed. THey had an issue with some of the others being to close to the K-member, but I have not had any of those issues with the few sets I have installed.
Old 12-11-2004, 07:24 PM
elite22xl's Avatar
i know 2 guys with jet hot headers, they love them
Old 12-11-2004, 07:42 PM
67SS&99SS's Avatar
I've had mine for 4 months and couldn't be happier. They do not bang and they went in exceptionally easy on both sides. Sometimes the engine has to be lifted a slight bit for the drivers side header with some brands, but not Jet-Hot. The driver's side went in easier than the passenger side to me. I did not go with a y pipe set up, as I have true duals. You won't regret the JetHots. Go for it.
Old 12-11-2004, 07:45 PM
2MuchRiceMakesMeSick's Avatar
Great header for the price. You do have to wipe them down every so often.
Old 12-11-2004, 08:12 PM
GM Muscle's Avatar
I love mine, they slid in no problem. They are quality pieces too.
blkZ28spt's Avatar
I like mine. Had to notch the K-member a tad, they cleared until the engine torqued when placed in gear the tolerances were so close. I do, however, wish that I had the money for kooks/qtp stainless because mine sees winter.
Old 12-11-2004, 09:02 PM
wipe them down? you mean for looks?
Old 12-12-2004, 06:15 AM
jrp
SN95 Director
jrp's Avatar
no problems with mine other then needing to grind down the block tab a bit to get the drivers side header in.
Old 12-12-2004, 06:53 AM
Jethot says to wipe them down. Some people have had some issues with them rusting after a few years. I have had mine for about 8 months with no issues.
Old 12-12-2004, 07:04 AM
redrocketls1's Avatar
a buddy of mine got some jethots and offroad pipe for his stock ss catback... rest of the car being stock "98ss" dont worry i still waxed his *** but it went from 9.14 @81 to 8.74@84 they look really good under his hood too!
Old 12-13-2004, 09:55 AM
SSCamaro99_3's Avatar
Mine cleared very well, just the driver's side tab was an issue. The headers have a little surface rust on them, but after two years and some salty roads I am not too concerned.
Old 12-13-2004, 10:28 AM
GuitsBoy's Avatar
I coated my jethots with VHT flameproof clearcoat for additional protection. After 7 months, I have no rust, not even surface rust. The clear never peeled or flaked off either. I did have to notch the K, but overall, I am very happy with mine.
-Tony
Old 12-13-2004, 10:38 AM
TAQuickness's Avatar
JetHots are a quality peice. The Y is a POS. I installed the JetHot's at the same time I was re-installing my motor. They seemed to want to catch on the left rear machining tab. I unbolted the motor mount, lifted (rolled) the engine to the right side and it slipped right in. The only thing I don't care for is the #8 spark plug. Not that #8 is easy to get to in the first place, but with the #8 primary directly in front of the plug, it's a bit more challenging to work with that plug.
Old 01-11-2005, 03:42 AM
Richiec77's Avatar
-Tony
Where did you get the VHT clearcoat?
I've been looking at getting these. I know their y-pipe is crap. From what I've seen the My choices are either; TSP ORY, Hooker ORY, or the Mufflex ORY. Think I'll go with the TSP piece unless some say's otherwise.
Is the Mufflex piece worth being almost double the Price? ( have to spend 25 more for a reducer)
Old 01-11-2005, 08:20 AM
GuitsBoy's Avatar
I got VHT clear (1200º) from jegs. Its still working pretty well, and has been holding up against the road salt now that we're half way through the winter here in the northeast. I was just under the car 2 days ago. the rest of the exhaust that I fabbed up is however starting to rust a litle at the welds.
Old 01-11-2005, 08:42 PM
Richiec77's Avatar
Thanks for the info man. I try that stuff out.
Old 01-12-2005, 02:05 PM
parbreak's Avatar
I love my JetHots, the headers that is. Their YPipe is a piece of crap. Took damn near as long to install the YPipe and get it to line up as it did to take off the manifolds and install the headers. Only thing I had to do was grind the casting tab on the block and they slid right in.
