Kooks vs QTP - ground clearance
Any pics or input is appreciated. From what I have read it seems that Kooks clearance is hard to beat. Also any input on the Kooks y-pipe, QTP seems to have some fitment issues.
For ground clearance you should be fine with both. Don't have either, but I have heard that when I was shopping.
I have never found a y-pipe that fit perfectly for anything though.
These headers seem to both be excellent quality, I'm getting whichever is cheaper.
I have QTP's, and I don't see how they can be beat for fitment. They tuck up under the car as tight as they can go without hitting anything under acceleration. This pic isn't at the right angle but it's all I have from my intall pics.
i run the QTP... i had no fitment issues at all..they fit just right.. i have heard that those that have fitment issues is mostly because they cant get the car off the ground high enough to work comfortably... you cant beat that true merge collector.. thats one of the reasons i got it..
here is a pic of how much clearance i get from the ground with my QTPs ... cant you see its a few feet
I went ahead and got the QTPs w/ the merge collector. I'll get some dyno numbers with my Dynatech stepped headers with merge collectors, then with the 1 7/8 QTPs with merge collectors.
Here's are a couple shots of my Kooks...they tuck in very nicely:
https://ls1tech.com/forums/attachmen...chmentid=13599
https://ls1tech.com/forums/attachmen...chmentid=13597
