Where to get crank bolt or threaded bar?
Old 01-18-2005, 06:19 PM
Red99TA's Avatar
Default Where to get crank bolt or threaded bar?
I've finished installing my cam and all the springs and now I'm about to start the reconstruction process. Where can I get the 120mm crank bolt or the 24mm x 2.0 pitch threaded rod? Home Depot doesn't have a bolt that long and I have no clue where else to look. I don't want to try to pull the balancer back on using the stock bolt and risk stripping the crank. Thanks in advance.
-Geoff
Old 01-18-2005, 06:26 PM
ILLWS6's Avatar
https://ls1tech.com/forums/showthrea...ght=crank+bolt
Old 01-18-2005, 06:31 PM
DARK AGE 53's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/250211-installing-underdrive-pulley.html
Old 01-18-2005, 07:30 PM
Red99TA's Avatar
Thanks for the posts but I can't wait to order a bolt. I geuss I'll try baking the pulley to about 300 degrees in the oven. Any reason why people do 200 degrees instead? I figured 300 or even 400 would work better. Also, can the threaded rod be bought locally?
Old 01-18-2005, 07:35 PM
ss rally red's Avatar
Napa has 16X20 MM threaded rod & longer bolts with the same pitch.
Old 01-18-2005, 08:56 PM
fasteddyss's Avatar
I would not get it too hot. You might melt the rubber insulator!
Let me know how it works. I will be doing it this weekend.
Old 01-19-2005, 01:25 PM
Red99TA's Avatar
well the oven trick didn't do a damn thing so I used a propane torch and heated up the center of the pulley for a few minutes and then it slid right on. I was skeptical at first but it was amazing how easy it went on after heating up the center of the pulley.
