My Pacesetter broke at the passenger air tube weld!
Has anyone heard of this happening before? I was on 101 last night racing an 03' and all of a sudden I got some bad backfireing on decell and heard a mild exhaust leak from the front passenger side of the car. I figured it was leaking where the clamp is by the header on the passenger side, because I hadn't had time to go get the ORY welded yet. Today, before going to the exhaust shop, I decided to change my plugs. It wasn't til I got to the #4 cyl plug that I relaized that the block off plate was sitting a little lower then it should be. A little wiggleing and I had found my problem. I'm going to the exhaust shop in a bit, I hope they can just weld the hole up for me... what a pain in the ***.
The pictures dont show the crack to well, I kinda put the tube back in place since it hadn't broken all the way off yet.
Sorry to hear about it.
I tried to get my Hooker LT's repaired and no one would do it unless the header was removed from the car. The air tube for the driver's side broke rendering the car useless. You can try some exhaust shops and maybe you will find one. I ended up removing, repairing and selling them for the QTP's.
What if i just pull the damn thing off since it's blocked off anyway and have them just weld up the hole?
Mine broke also, same tube. I cut the air tube off, brazed the hole shut, placed the piece back into the hole on the header(lined it up where it broke out). Then I wrapped a hose clamp around it for a tempry fix until I purchase a set of GOOD SS headers. I am not driving the car in the winter but it sucks that it happened right before I put it up. Mine are rusting very badly and only 14 months old. Coated in case anyone wonders about that.
