TSP Offroad Y-pipe
TSP Offroad Y-pipe
How many people have this? Is it a good buy for my pacesetters? I don't want to go true duals (well I do but can't because of emissions and I cat afford over the axle...now!) and need a y-pipe but didn't go with the pacesetter y-pipe since I heard bad things about it. How do you think it will sound with my pacesetters, TR224 at 112LSA, and a hooker catback (The only one installed now is the catback)? What is so good about the flowmaster collector? Should I weld that onto a y-pipe? Any other suggestions for an offroad y-pipe? Thanks in advance.
I had to adjust mine because it was hitting hard, however it still hits under the car a little. I can still go over speed bumps and need to keep it that way. I am putting poly motor mounts on to keep it from hitting, and hopefully I can tuck the y back up a little. I have never messed with other y pipes, but in my experiance you have to have the driver side pretty low with the TSP to keep it from hitting the car under accleration.
