What is needed for Pacesetter lt? For installation which tools?
Old 02-10-2005, 02:06 AM
rawlitogut's Avatar
Default What is needed for Pacesetter lt? For installation which tools?
I have pacesetters lt and y-pipe on the way. I have i o2 sims and o2 extensions. Can i reuse the old bolts and gaskets? What tools do i need,also do i use ani-seze?
Old 02-10-2005, 02:53 AM
jrp
SN95 Director
jrp's Avatar
https://ls1tech.com/forums/showpost....64&postcount=2
Old 02-10-2005, 06:11 AM
My-bird99's Avatar
definatly replace the gaskets,not with the provided paper ones either,you can pick up the metal gaskets at the dealership,pretty inexpensive.The paper will just blow out and you'll be stuck changing them out anyway.
Old 02-10-2005, 11:15 AM
SSU's Drunk Typing Whore
Lithium's Avatar
10mm gear wrench is a must have, also spray all the cat bolts with WD-40 the night before. I skiped that and payed for it, those three bolts are on there good. Took me about and hour to get those damn things off. (And read jrp sticky)
Old 02-10-2005, 11:36 AM
hourang's Avatar
you can use the stock gaskets and bolts perfectly fine. done it on 2 vehicles, 0 leaks. i had 55k miles on mine, gaskets were still good. if there obviously bad dont reuse of course.
