Y-pipe fabbing...few ???'s
Due to the poor design of the catted y-pipe i bought last season, ive decided to just have an exhaust shop custom make me a y-pipe for my SS...i have QTP LT's and LM catback exhaust right now, My question is, should i keep the y-pipe 3" or should i make it 2.5"? I dont understand the diff....and truthfully i was deffinatly NOT impressed w/ how quiet it sounded w/ the 3" ypipe i had on it last year....however, it is the qtp catted y-pipe so i have two cats...which are now hollowed out, and the flowmaster merge....which were all originally for the 3" diameter...can a shop make them work w/ 2.5" or not likely? Thanks for any info.
There are different ways to do this, the pipes coming off the headers will have to be 3", then they can use reducers AFTER the cats to complete the y. I wouldn't do it though. You'll probably sacrifice some power and it will be quieter than the 3". If hollowed cats through a LM catback isn't loud enough, then you'll have to step up to 3" duals dumped, or get some cutouts. Cause there isn't a y-pipe/catback combo out there that will be louder than what you have. Unless you just dump a bullet right at the end of the y-pipe and ditch the LM.
Just my 0.02
Just my 0.02
Is there emissions testing in CT. I'm guessing you want to keep the cats for visual right? Otherwise, what is the point of having them at all. A buddy of mine hollowed out his cats on his Cobra and I was thinking WTF? There aren't any emissions tests in MI, why didn't you just get some straight pipes or something. Would've been cheaper.
Yea emissions alright..i hate it...as far as i know its OBDII w/ a visual scan for cats. As long as i have no thrown codes i'm all set....so if i dump right after the y-pipe and put a bullet is that considered legal? From my understanding as long as i have a muffler or something to take the place of a muffler then i'm all set. I cant do cut outs i thought b/c i am keeping the damn shells for emissions purposes . So a 3" pipe will be louder than a 2.5"? i thought b/c of having more restriction in air flow it would get louder. So if i keep the 3" pipe and dump after the y..w/ a bullet it will be louder than a 3" w/ the LM? Thanks for any info.
Go with the 3" y-pipe to the LM. Then if you decide to do duals later on you have the option to cut the y-pipe and run 3" or 2.5" duals whichever you choose.
You probably won't pass visual with the bullet dumped after the y. It's my understanding that the exhaust has to exit behind the passanger compartment to be legal. Maybe someone else will chime in on this though.
Ok, i will do the 3" y-pipe....but i was actually considering what kpowr said before w/ the bullet. I was looking into it and if i remove my LM and put the 3" y-pipe in...then put a bullet right after the y-pipe and thats all...technically i'll be legal and pretty loud right? I drove around w/ open headers for the entire summer last year and no one bothered me, so i'm not worried about that, but emissions wise...my other question is....i went to dynomax, their bullet looks exaclty like the "muffler" or bullet that the LM uses in the i pipe....can i just cut and weld that on to the end of my 3" y-pipe and call it a day.
Ok...so viusually if i do the bulllet and then dump and fail...technically all i'd have to do is fab a pipe extension to put it a little farther back, clamp it on and i'll be set for the emissions...then after emissions i can go back to the first idea w/ the bullet right after the y?
I'd stick with 3" for performance sake. Dynomax makes the bullet your looking for. Many of our sponsors carry them. Actually, I have an extra one left over from my TSP true duals. I bought some sweet thunders instead. It has a turndown welded on it too. Let me know if you wanna buy mine.
