Cats for my ory???
Cats for my ory???
im considering getting a pair of high flow cats to kill my rasp problem. but heres my problem....when i went with my ory pipe, i removed my rear o2 sensors and had them deleted when i had my car tuned. if i reinstall cats in the ory pipe and buy new o2 sensors, is there a way to "undo" the cat delete.....or tell the computer i have cats again so they will function?
For what? The cats will function just the same, don't waste any money on new sensors and a tune. The only thing the rear o2's do is tell you IF the cat is functioning properly. If you already had the code deleted, forget about it. Just get the cats and be done with it.
BTW, I believe when you had the code "deleted" they just turned it off. So turning it back on should be a piece of cake.
