Crank pulley wobble
Crank pulley wobble
Hello yall today i went under my car while the engine was on and noticed the crank pulley to have a slight wobble. Seems like it is not spinning true. Is this normal? I am gona try and retorque it down. What can be causing this to happen? Should i be worried? Does anybody else notice there car doing this?
I had the same problem with my stock pulley. However, when I installed the ASP pulley it was fine. Here are a few things you can do, even in this order.
First take the pulley off then re-install it with a new crank bolt.
If that dosent work, then try to find a used stock pulley at a junk yard, or shop. Install it, and see if that helps. Something may have happend to the old pulley at one point to warp it.
If after that, you still have the problem, I would take it to a reputable shop and have them check the crank.
Pray that you don't have to get to that step, because that would require some cash for them to check and possibly fix. Good Luck.
Also, be sure not to spin the motor too hard in the mean time, because if it is an imbalance, something in the engine could let go.
Originally Posted by LS1FIRE
How can i tighten the crank pulley bolt without spining the crank? Will i need a tool?
Make sure you get a few new crank bolts as they are single use only. A tourqe wrench and a breaker bar helps as well. The auto zone by my house rents those as well.
You don't have to worry about the crank spinning if you have an M6, just put it in gear. For an A4 you will have to drop the cover next to the starter and wedge a screwdriver in between the flywheel and the housing, or you could try to find a flywheel locking tool if you wish. Its easiest if you know someone with a lift, but you can also do it with a set of ramps or a few jack stands.
Hope this helps.
