power steering pulley replacement
demolished power steering pulley replacement
Ok my power steering pump pulley had been broken off at some point and I need to get my new one one to the pump. There is a small metal collar from the old pulley still remaining on the pump and I need to get it off. Any ideas?
Also whats the procedure for installing the new one.
thanks
thanks
Originally Posted by John_D.
There's a puller that clips over that collar to pull it off.
The new one has to be pressed into place. An SAE stud and nut can be threaded into the hole to press the new one on. I don't remember what size, but I know it's not metric...
Also how do you stop the pulley from moving as you tighten down the bolt
