engine dies on right hand turns
wheneve i make a right hand turn the engine stutters for a sec and cuts off. speed doesnt matter and does it with clutch in and out. when it stalls the check engine, check guages, skip shift, low oil light comes on. the oil level is fine, and it has the skip shift resistor in it
it is a 98 ls1 with a t56
Yeah my 85 used to do that when it was low on gas. I would check your entire fuel system over, replace the filter, run some injector cleaner through it and check your presssure.
