Questions on Longer crank pulley bolt
OK I need some answers on this whole "long pulley bolt" dilemma.
I am doing my cam soon, and I bought a ASP pulley. I was told it's a good idea to use a long crank pulley bolt to pull the crank on a little bit before you pull it in the rest of the way with the old bolt. Is this right?
Do I only use this long bolt to install the pulley?
Once the pulley is seated on the crank, can I leave the long bolt in there? Or do I have to buy a new TTY bolt from GM?
As far as removal....do you need to use the longer bolt for the removal of the old pulley?
And one more final question...when I do this cam install, what bolts need loctite, and what strength loctite do I need?
Sorry about all the questions, I hope this clears things up for me.
Thanks a lot...
Thanks a lot...
Having just done mine last weekend, it a lot more clear to me now. The reason the short bolt gives you trouble is because the pulley hits the base of the head (closest to the threads), while the pulley still needs to come off further. You dont need a longer bolt if you have an object lying around about 2 inches long that will fit into the hole of the pulley. You can stick this in there against the front of the crank and put the puller tip on that. FWIW, if you can get the proper pitch longer bolt ahead of time by all means do so. I just had to improvise.
About the loctite, i used red on the crank bolt. I know people say it calls for blue but i swear to god ive never had one problem removing a bolt with red loctite when it came time. Now the head bolts may be a different story.
Also, you are supposed to use a new crank bolt as they are tq to yield. I forgot to pick one up so i reused the one i had. The "proper method" is tq to 240lbs then 140 degrees, then back out bolt and tq new bolt to 37lbs, or something like that........I hit it with an impact on high.
OK I'll have to grab a new TTY bolt from GM.
Do any of these bolts need loctite? If so, what strength?
Valve cover bolts, rocker arm bolts, oil pump, water pump, cam retainer plate, timing cover??
I think the proper method is using the old bolt torque to 240ft/lbs, remove old bolt install new bolt to 37ft/lbs +140 degrees. Do not attempt to torque the old bolt to 240ft/lbs + 140 degrees as you will have "crank shaft issues" after the bolt breaks. BTW I did not use any Locktite on my crank bolt, now about 5000 miles.
Originally Posted by ArcticZ28
if what's required?
Heh...we posted at the exact same time...I was wondering if it was required for the crank bolt or not...but you answered my question as I was.
Originally Posted by WS6FirebirdTA00
i was told to use some silicon sealer on the rocer bolts to prevent oil from leaking into the intake port
i will be getting an arp bolt for the crank, i have a brand new gm one i will sell u if you want
Thanks anyway, but by the time I pay for s/h, I can go grab one from a dealership.
Loctite should not be necessary on the crank bolt if use the GM bolt. However, I don't really see a problem doing it. I would use blue personally.
I would not recommend putting the crank bolt on with an impact though.
Originally Posted by Loctite.com
Q: What do colors mean?
A: Many times Loctite anaerobic materials are called " the red or the blue stuff". With threadlockers, colors designate strength. Generally red means high strength and blue means moderate strength, and purple is low strength. Other colors do indicate strengths in relative areas
Why would you not use "red" since it is a higher strength for higher temperatures than "blue"?
And as far as not using the impact. When we had 2 people cranking on the bolt i was actaully scared the bolt would snap. I know its probably just in my mind. However, i know how strong our impact is from using it all the time so even though its not recommended....i did it. Just a nice tipity-tap-taparoo.
Originally Posted by bowtieman81
I think you are explaining how remove the pulley in your first paragraph, not install it. However, I agree with your method and it is what I used the first time. However, I think the best method is to used a solid piece of round bar stock that sits on the crank snout so you don't touch the threads at all. That is what I will do this next go around.
I went and bought a new GM crank pulley bolt today. Also, as for the installation of the new pulley....
-Do you guys throw it in the oven? Or does this not work?
-Is this the proper procedure for installing the new Pulley?...You use the long bolt to pull it on the first 1/4" or so, then put the old bolt back in and pull it in and torque to 250 ft/ibs...then pull the old bolt out, then put the new GM bolt in and torque to 37 ft/ibs +140* rotation.
I did not bake my pully, just stuck it on the end of the crank & carefully used a long bolt to draw it on a ways, then switched to the old crank bolt, completely seated the pully with that & torqued to 250ish. Removed old bolt & installed new torqued to 37 + 140 degrees. Let me tell you that 140 degrees requires a very long cheater bar.
i bet so, thats prob torquing that damn thing to 500 ft lbs
anyone know how to do the arp bolts?? i was reading that someone said to get arp and not the gm one because they can bust, this true?
