Questions about cat. converter and knock retard
First question, how hard is it to take off the cats? Second question, could something rattling around inside my catalytic converter cause false knock? Thanks!
I don't know about the cat causing a false knock. You can unbolt the pipes to get to the cats. I don't remember if the cats are bolted, but the probably are. The head pipe bolts to the y pipe and the cats bolt on the y pipe. Not hard. Good Luck.
LS1Tech Administrator
Received 1,493 Likes
