header install...reuse stock exhaust gasket??
i reused mine, and they dont leak. the car had about 65000 miles when i did it. i have had to go back and tighten a few of the bolts again, but thats normal if you dont have (or are too cheap) to buy locking header bolts.
If your going from your stock manifolds to headers, I would use new one's! If your putting on the same headers with the same gaskets and there in good shape, you MAY be ok using the used gaskets.
