Question On Kooks Headers Install?!?!
Ok I Just Ordered Kooks Headers And Am Looking For Install Instructions. Proper Torque Specs If Any And If Lock Tight Is Recomemended For Header Bolts. And Do I Have To Run Engine For A Bit Then Back Off Bolts Re-run Engine And Back Off Bolts. Any Process Like That. The Headers Are 1 3/4 S.s. Long Tube High Flow Cats And Y-pipe W/ Egr And Air Fittings. All 3 Inch Going In To A 3inch Corsa Cat Back System. I Have A Bunch Of Ther Mods Done As Well In The Works Any Info On This Would Be Helpfull. Thank You
I Haven't Tried A Search Yet The Info I Get Here Is Always Quick And Accurate So I Start Here First. Thanks So Far . Guess I Will Just Tighten Them Up And Go For It. Can't Wait For Install, What Are The Gains I Should See H.p. And F.t Lbs. I'LL CHECK OUT THAT SITE TOO \
