Need HELP ASAP!!! Window Motor doesn't work after new install!!
After I installed the new window motor on the drivers side it still doesnt go up or down! All i hear is a buzzing under the dash when i push the button!! What the hell? PLEASE HELP!!
Will the driver side switch operate it? I think the driver side is the master switch. You need to see if you have continuity between the window motor wires from door to door. Pull both switches and check for voltage when buttons are pressed and contnuity from switch to switch in operation and at rest.
The door lock button on he drivers side makes a bing bing bing noise when i press it. Other then that the rest of the switches work fine. How can i check if the motor is bad??
