ASP pulley?
Old 06-23-2005, 11:54 PM
BADBOYZ28's Avatar
Default ASP pulley?
Hey I'v heard that on the older style ASP pulleys if you put a double roller timing chain you have to shave some off of the back for them to sit right. Does anyone know how much to shave off? Any help would be appreciated........
Old 06-24-2005, 03:22 AM
Nocturnal SS's Avatar
What kind of tires were you using when you ran 11.74? also what was the DA.
1.600 60ft is good.
Old 06-24-2005, 05:01 AM
Y2K SS's Avatar
Really??? Is this just for the older ones?? I was just going to order one too. I'd like to know the answer to this as well.
Old 06-24-2005, 05:59 AM
nostyta's Avatar
Here you go hope this helps.
3mm must be taken off.
Old 06-24-2005, 10:12 AM
BADBOYZ28's Avatar
1.600 60ft is good.
I was running 28x10.5 ET Drags. As for the DA I'm not really too sure.
Old 06-24-2005, 10:15 AM
BADBOYZ28's Avatar
Ok cool thanks. What tool would I use to shave it off? Also is there a possability that it might be uneven afterwards and what kinda problems would cause?
Old 06-24-2005, 10:23 AM
777's Avatar
You would probably need to take it to a machining shop so that it would be even.
Old 06-24-2005, 11:01 AM
Y2K SS's Avatar
ummmmmmmm
Old 06-24-2005, 11:03 AM
777's Avatar
This is just for the older ones. The new ones have been pre-machined from the factory.
Old 06-24-2005, 11:15 AM
Krab's Avatar
I've got a rollmaster double roller chain with an ASP pulley and haven't had any problems in the year or so I've had the pulley on.
Old 06-24-2005, 02:49 PM
BADBOYZ28's Avatar
Is it the newer style ASP pulley or the older one?
