Code 1153 With Long Tubes
Old 07-03-2005, 08:31 PM
hllywd's Avatar
Default Code 1153 With Long Tubes
Im not sure if this is the right place for this but Ill start here anyways.
I installed LT headers last year W/O cats. I put the factory O2 sensors back in and after about 50 miles code 1153 poped up (insufficient switching). Cleared it with my predator.
This year I replaced the sensors with new Bosch ones same thing happens after about 50 miles, code 1153 again.
Ive heard that this is common when LT headers are installed W/O cats.
Is there anything that can be done short of deleting the sensors?
Anyone else take care of this problem?
What would be the fallout if I delete the sensors in the PCM?
Thanks in advance
Old 07-03-2005, 08:37 PM
gomer's Avatar
Every car I tune that has longtubes gets the 1133 and 1153 codes turned off on them. Disable those two codes and you'll be just fine.
