dealer replaced water pump now my 160 stat won't fit
The 160 stat is to large to fit into the new pump. The dealer must have used a different model pump. The opening to fit the thermostat is much smaller than the stock one. Did Gm make different water pumps for ls1's. Did I get a LS6 water pump if there opening is a different size?
GM udated all their pumps to the 04+ design. you will need to get a t-stat for a 04+. http://www.vincihighperformance.com/...TS%20PAGE.HTML about midway down on the left. NEW! 170 DEGREE WARM WEATHER & HIGH PERFORMANCE THERMOSTAT
FOR 2004 CORVETTES
OUR NEW THERMO HAS OUR SAFETY BYPASS AND A NEW HIGHER FLOW
HOUSING. BEWARE! THE PREVIOUS THERMOS WILL NOT FIT THE 04!
MANY OF THE 97-03 REPLACEMENT WATER PUMPS NOW REQUIRE THE 2004 THERMOSTAT!
$89.00 it's a t-stat and housing as well.
FOR 2004 CORVETTES
