sweet thunder true duals-Get in here
Here's one pic I have, showing from the rear (sorry the car's dirty). Also the red WS6 on the right has duals, but his bulkier mufflers don't have near the ground clearance as the Sweet Thunders do
I'll search for the other pictures I have
*edit* Re-read your post, saw you wanted to see them out the back. Mine are dumped at the axle, sorry. But this shows some ground clearance none the less
Here's mine. 3" dual cutouts>3" to the X-pipe>3" X-pipe> 2.5" reducers into 18" Sweet Thunders> 2.5" pipe over the axle> dual/dual tips
So far the lowest point is the bottom of the cutout flanges. Next lowest would be my mufflers. I still believe i could have taken 2.5 over each side ( instead of both going over the passenger side ) and gotten the exhaust to tuck up a little tighter.
Hope this helps.
Labor= $400
The Looks that you get when you fire it up.....PRICELESS!
Damn, that's awesome. Thanks. Have a sound clip?
From the side to see the height
Now the exhaust from the rear. I'll measure the clearance at the lowest spot and get back to you if I can remember.
THAT'S LOW!!I could never get away with that here in GA. The DOT here puts temporay steel plates on the road over holes that their still working on and would rip those right off my car for sure! Good thing you live in flat florida.
Sharpe- pm me your e-mail addy and i'll be happy to send you a short video
