ignition problem
ignition problem
Here's one for you ignition gurus. I have an ticking/arcing sound coming from coil #3, when you run a cylinder test on EFI Live when it tests that cylinder the ticking/arcing noise momemntarily goes away.
I have replaced the spark plug, no change, replaced the plug wire, no change, replaced the coil, no change.
Any ideas?
Thanks
Any ideas?
Thanks
