Another fan switch question
I've done a good bit of searching and found lots of links that don't work on this subject. Can anyone tell me specifically where I need to tap in to the wires for the fans? I keep hearing a blue and green wire on the passenger side of the inner front fender. I found a 10 wire connector there with a green and blue wire, actually there's more than one of each. Is it the two that are next to each other at the connector? And also where are most of yall getting the wires through the firewall? Thanks in advance.
Location: Live Oak, FL - in the woods where the creatures lurk.
Here's something I wrote up for someone a coupla years ago. Hope this helps.
This is from memory and for the 2000 ECM pin-outs.
I tapped into the wiring harness that runs over the pass wheelwell to the computer. To do a quick test, you can pull the large connector apart on the wheelwell and look look for the pins that correspond to the Dark Green wire (low speed fan relay control) and the Dark Blue wire (high speed fan relay control.
With the ignition off, take a probe or wire and touch the Dark green wire pin and put the other end to ground. The fans should come on low speed.
With the green wire still to ground, take another probe or wire and touch the pin that corresponds to the Dark blue wire and put the other end to ground. Fans should now come on high.
In other words the Dark Green wire to ground will run the fans on low. Both the Dark Green AND the Dark Blue to ground will run fans on high.
Don't have to cut any wires, just use the crimp-type (tap in squeeze ) connectors available at Radio Shack.I tapped into the wiring harness at the rear of the wheelwell and thus could route the wires in existing split-cover up to the computer. If you take the computer MOUNT loose you can get some wiggle room and there is a grommet behind and down that you can snake the wires inside behind the pass kick panel, then route through the dash.
Incidentally, there is a good ground source behind the pass kick panel you will see wire(s) bolted to.
I don't remember the switch wiring off hand.. A 3 position dbl pole/dbl throw will let you wire for off, low, or high speeds. Good luck, it doesn't take very long to do. My switch is mounted to the left of the "CAMARO" lettering on the console.
A small switch will fit into an empty plug there, but the larger one I used took gluing in a drilled piece of black plastic
If you follow my instructions you can't go wrong. Mines been wired that way for years. If you use the 3 position switch, it allows for fans off, fans low, fans high. You could use a 2 position switch and have only off and either low or high. One of the poles on the switch will be your ground, and if you decide to have both high and low speeds (3 position switch) you will need to solder a bridge between the two sides to provide a ground for both wires.
i bought my switch off of ebay as did a buddy of mine its a great piece comes with wires switch and (2) led's lights so you can tell when they are one it was like $30-$40 bucks. but this was like over a year ago
