YPipe i can use with stock manifolds?
im not looking for gains....my factory ypipe is rusted inside and causing a vibration through the whole car so im just looking for a replacement basically....the flattened factory peice doesnt look like it helps anything though so id rather get an aftermarket....plus money is a little tight or id opt for some headers to got along with this.
so where can i get the bassani one? i called slp and they said it would not work on my 99 because the 98-99 y-pipes were shorter and to use this one id have to cut the pipe and weld it together again.
No matter what y-pipe you get it will have to be welded. The 98's and 99's have there stock y-pipe welded on the passenger side, unlike the bolt on style of the 00-02's. I have the SLP y-pipe on my 98 and know many other people that also have them on 98's and 99's. The SLP y-pipe will work on your car just as well as any other y.
I know Mac makes one for stock manifolds. I had one on my 99 and it was a direct bolt on. I really liked it for the price and the car seemed to perk up with the cats off. Check around and you can probably find a decent used one.
QUOTE:im starting to beleive that there isnt a y-pipe left for my car unless i go with headers.....GM even discontinued service on them. lol damn it!!
You must have missed both my posts. The SLP one works, I have it on my 98 which is the same as yours. Bassani also makes one. Those are two you can use right there.
