oil between header gasket and head?
i checked my header bolts again today b/c im paranoid like that, and i noticed some oil between the header gasket and head...i took the header bolts out and one of them had oil on it? as if it came from inside the head...there 5.3 heads with stg 1.5 work done...just wanted to know if this can be at all normal? one thing though, i took the valve covers off a week ago to double check the rocker arms, could have spilled alil oil and got onto the head, but i figured that would have burned off...noticed this on both heads...any idea's?
Jon
Jon
Originally Posted by JoeyAnderson
Could it be a leaky valve cover gasket?
Jon
Yup. My vote is a leaky valvecover gasket. Pull the valvecover and see if the gasket is twisted. If so, you may be able to twist it back into the groove without buying a new one. If you do need a new one, they're relatively cheap.
My car came from the factory with a twisted valve cover gasket. Didn't start leaking till ~35-40K miles.
Jon
