temp gauge sensor bung
just ordered phantom gauges, turns out mechanical were sent instead, later on finding out theres more pros than cons...anyway i heard of people tapping into the radiator hoses, kinda like using a stock ps pump cooler idea....i know thats kinda hard to follow, im tired tho its late....anyone know how to make this work??
BMW ///M Nerd
You don't want to tap into your radiator hoses. I don't understand why people would do that?
You can either do what Schantin did, or tap into the back of the passenger cylinder head. Your using a mechanical gauge, but as previously stated, it's the same concept.
You can also pull a plug that is above the starter in the block. You need to buy an M16x1.5 plug/adapter though. You also need to drain the coolant if you go this route.
