jus got my 00 Z comp scanned for ses
2 of my o2 sensors are bad, so im gonna go ahead and replace all 4...was looking to buy used off a guy at a camaro salvage and he that claims has only 7500 miles on them and guarentee's them..i need to know are there diffrent part #'s for all 4?and where to find the part $ of them?? i think the 2 in front are both diffrent and the back 2 are the same, so im looking at 3 diffrent part #'s( i think)..does anyone know which one goes where, the part #'s im needing and which banks they go in??and are all Ls1's the same, meaning can i fit some out of a 99 into a 00?? or a 02 into a 00??could use some help....mine is a 2000 Z28 ...could use some help...thanks!!
In stock trim they are all the same with one exception… The passenger side front O2 has a shorter length cable on it. You can use the longer ones at all 4 locations with no problem. I don't have the part numbers handy (two of them) but if you do some searches you will find them.
Originally Posted by jandruzi2212
i can put sims on the back instead of putting 2 new ones back there also?? i still have my cats and everything on, will that matter?? wont the o2 sims throw a code??
no o2 sims stop codes from popping up because of bad cats. the rears do nothing but monitor if the cats are working or not...the fronts are the ones that matter.
rears monitors hardly ever go bad,unless you get a heater code. it really matters what codes you got. could be a vacuum leak or other things.2 sensors going out at one time is really odd.
