removing AC
removing AC
any write up on this. i think i wanna remove mine. i dont use it and when i do the car runs like ***. i just wanted to see if there was a proper way to do it before i start ripping things out.
proper way?........
just start rippin it all out.
and while your in there dont forget to pull out the egr/air if you allready didnt.
and i also removed the wiper fliud res.
no the radiator has alot less **** in front of it!
just unbolt a hose and let it come out. Is this your DD? I wish i could get rid of my AC because the **** never works, but summer in MD is a bitch, i already had to go without it for almost the whole summer and rolling the windows down just doesnt cut it. Cant escape the heat when you got hot *** air blowing on you. And also in the rain, when it is still hot, maybe its just my car, since it is black its like an oven.
SSU's Drunk Typing Whore
I am pretty sure our cars dont have freon (sp?)
I found some really helpful threads when I removed my AC. I will do my best to dig them up for you. I never used my AC as well, figured it was best to just pull it...
Pick up a Haynes manual as well, it has helped me out a ton over the past year.
Originally Posted by spy2520
accumulator, which is really part of the lines since it is permanently attached to one of them.
you could go as far as removing the evap.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I just did it today. it takes about 20 minutes. there are 6 bolts including bolts on the bracket with the pulleys on it. you have to take the back hose connection off in order to get the compressor out, and the dryer bracket is a Torx 40. looks cleaner with it gone as well. good luck.
